Motor cleaning
Old Marine Engine » Miscellaneous » Motor cleaning « Previous Next »
quiffhat
Username: quiffhat
Posted on Thursday, May 14, 2009 - 11:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I was looking for a safe way to clean my motor, without taking it apart. I found this on the net, a bit involved but worth reading. http://nautarch.tamu.edu/class/anth605/File10b.htm#Sodium
robert
Username: robert
Post Number: 280
Posted on Saturday, May 16, 2009 - 01:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You'll have to take it apart to use that method. Soda blasting is the only method I know of that will clean dirt and old paint off steel,brass & glass without damaging those surfaces.
Can be done wet too, with a pressure washer, a gravity or air feed pot and a blasting tip for your pressure washer.
