Please let me know if you find proble...
Old Marine Engine » Miscellaneous » Please let me know if you find problems on the site.. « Previous Next »
Posted on Friday, November 02, 2001 - 11:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
As you may know I have moved the OldMarineEngine.com site on to a new server as of November 1, 2001. Hopefully you won't notice much difference except for the new discussion board.
If you do find any problems such as links that don't work or photos that do not load... please let me know and I will try to correct them.
Thanks.
Andrew
ome
Richard Durgee
Posted on Friday, November 02, 2001 - 02:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Andrew: Can't get system to accept my old user name and password ! if I try a new one it rejects it saying only one username and password for each
e-mail address (catch 22). Richard Durgee
[email protected]
Posted on Friday, November 02, 2001 - 03:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard,
Thanks for pointing that out....
The username and password for the classifieds does not automatically integrate with the discussion board. You have to register seperately for the discussion board... unfortunately I am not technically savy enough to mesh the two together. You do not have to register to use the dicussion board (as you know because you just used it) but doing so will allow you to get email notification of your posts or other posts.
Register for the discussion board by clicking on Edit Profile on the left and then click on Instant Registration. You will choose a username (it can be the same as what you use in the classifieds if you what), and then the system will immediatly give you a password. To change the password to the one you want, go back into Edit Profile and edit your password.
Hope this works okay... if you have problems it may be the settings here and I can fix it...
Thanks.
Andrew
David Knutsen
Posted on Thursday, November 08, 2001 - 03:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Andrew.I have sent pictures of the old regal engine. Hope they can help to determine the age of it.To morrow I will try to get a good close-up of the nameplate and send it to you.
By the way, where do I find my pictures on your pages?
David.
