Amp Meter
Old Marine Engine » Miscellaneous » Amp Meter « Previous Next »
Posted on Saturday, July 26, 2003 - 12:54 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Any one familiar with or have a catalog with one of these in it ?? Lockwood - Ash amp meter about 2 1/2 inches in diameter .
Lockwood amp
Posted on Saturday, July 26, 2003 - 09:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have one. It's not Lockwood but similar. I also have a volt meter of the same style. I would call the amp meter a "shunt" meter and it is put across the battery just like a volt meter. (in paralel not in series with an external load like an amp meter would normally be used) It just measures the available amps across a shunt or load. (whatever it's internal load is) I would not put it across 12 volts. Mine works up 6 volts.
Hope this helps
Richard Day
Posted on Saturday, July 26, 2003 - 09:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I believe the real purpose of the ampmeter portion was to test the output of the typical No. 6 dry cell. A good one should be momentarily test about 20+ amps. Don'test but for a moment as you are draining the life out of the battery. The voltage measurement would be around 1.5 for a single cell. 6 volts for a hot shot battery and 7.5-9 volts for the typical 5 to 6 No. 6 dry cells in series for a Make and Break engine. Many of us had them as kids to test our dry cell batteries for filaments of our homemade "junkadyne" receivers. In the early years all self respecting owners with one lungers in their boats had them as a normal and essential part of the tool kit. So much for history as I lived it.
poker casino356
Posted on Monday, March 06, 2006 - 04:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 569
