MYSTERY ENGINE
Old Marine Engine » One and Two Cylinder Gas Inboards » MYSTERY ENGINE « Previous Next »
RSCOY
Posted on Wednesday, January 30, 2008 - 11:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can anyone identify this engine. It is very similar to a Waterman that has been shown on this site but there are differences. I assume it would take a Shebler model D carb. I'm not sure what the timer would be like as there are no gears like the Waterman and there is no eccentric to drive a pump. The red insulating ring appears to be part of the timer as it has a steel pin through to the crank shaft that would complete the grounding circuit.
Any help in identifying it and direction for a parts source would be greatly appreciated. I would like to get it to run again.
Bobwhat is it
Moderator
Username: andrew
Post Number: 913
Posted on Thursday, January 31, 2008 - 08:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bob,
It might be easier for someone to help if the photos were larger.
If you have trouble posting them let me know and I can do it.
rscoy
Username: rscoy
Posted on Thursday, January 31, 2008 - 05:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is an attempt to post the pictures of the engine larger and resized for this page.Mystery Marine Engine
paulgray
Username: paulgray
Post Number: 54
Posted on Thursday, January 31, 2008 - 07:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Judging from the offset cylinder, I'd guess Ramsey made in Philly
