Pump casting for Waterman K2
Old Marine Engine » One and Two Cylinder Gas Inboards » Pump casting for Waterman K2 « Previous Next »
raa
Username: raa
Post Number: 8
Posted on Monday, January 04, 2010 - 08:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If anyone needs a pump casting for his Waterman twin I will be sending the pattern up the the foundry soon. The casting is made with leaded bronze. I have increased the hub where the packing nut goes so that 1/4" square packing can be used and the neck which is the weak spot on the original is beefed up with a web.
finished pumps
solarrog
Username: solarrog
Post Number: 399
Posted on Monday, January 04, 2010 - 09:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have you ever thought about doing some Caille Liberty single timing levers?
solarrog
Username: solarrog
Post Number: 400
Posted on Monday, January 04, 2010 - 09:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What about casting gears or machining gears. I have a K2 with both drive and driven mag gears stripped of several teeth
rbprice
Username: rbprice
Post Number: 287
Posted on Wednesday, January 06, 2010 - 08:01 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Gears are my specialty solarrog - send me some pictures with a few dimensions and I can produce a drawing and get some prices on finished parts.
Bob Price
518.895.8954
