5 hp Atlantic
Old Marine Engine » One and Two Cylinder Gas Inboards » 5 hp Atlantic « Previous Next »
atlanticacres
Username: atlanticacres
Posted on Monday, August 03, 2009 - 06:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looking for a 5hp atlantic in Nova Scotia to replace my worn out one.
After 5 minutes of running time it blows smoke. Oil in bottom end looks milky. I assume it getting water in through the cylinder. Any thoughts would be appreciated.
Lloyd
rbprice
Username: rbprice
Post Number: 252
Posted on Monday, August 03, 2009 - 09:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Tear it down and replace the rings and see if that restores the compression. How old is the engine?
Bob Price
atlanticacres
Posted on Tuesday, August 04, 2009 - 09:22 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It's in my friends boat. Very old... probably fifties or late forties. Up till this year it ran flawlessly from year to year. In fact it starts every time now without problems. He noticed it smoking this spring. I will let him know and get him to post on here as well.
Many thanks.
Lloyd
PS: the boat is a bush island style boat fiber-glassed over. He saved the hull and rebuilt it many year ago. He rigged it for sail last year.
Boat
doug11k
Username: doug11k
Post Number: 64
Posted on Tuesday, August 04, 2009 - 09:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Lloyd,
Check the divider in water cooled exhaust manifold between exhaust & water sides ... probably wasted through .... easier to eplacing gine. Have a friend that has same problem on a 4 hp Atlantic
