"Pullin on the Rex"
Old Marine Engine » One and Two Cylinder Gas Inboards » "Pullin on the Rex" « Previous Next »
Post Number: 2212
Posted on Wednesday, October 14, 2009 - 07:13 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
"Pullin on the Rex" 1915
prex15
Post Number: 1072
Posted on Wednesday, October 14, 2009 - 09:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks like a good way to break a flywheel to me.
Pulling that far from the center on an unreinforced area is sure to make little parts out of big ones
Post Number: 483
Posted on Thursday, October 15, 2009 - 07:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If I smash this puller, where do I send it for replacement? That's an 8" wrench for relative size. crown
kerrigan
Username: kerrigan
Post Number: 31
Posted on Thursday, October 15, 2009 - 08:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie:
What tool would you use to pull that flywheel? One with 4 claws instead of 2?
richardday
Post Number: 820
Posted on Friday, October 16, 2009 - 09:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Myself I would not try to pull a spoked flywheel which is rusted to the crank. Make up two inch thick steel plates about a foot square. Bore a clearing hole in the center just clearing the crankshaft diameter. Saw clearing width slots to the center hole but save the pieces. Mount the crankshaft in the press with the two plates so when putting the cut out piece in the top plate just under the flywheel it fills in the gap in the top plate. Cut a couple of pieces of sheet lead with a hole the size of the crankshaft. Slit the sheets of lead so they can fit around the crankshaft. Arrange the slits at 180 degrees. The purpose of the lead sheets is to insure no small high spots can in the flywheel hub will cause the pressure to possibly crack the hub.
Using this approach I have suceeded removing badly stuck flyweels with no breakage. Guess there will always be a first time. I never use heat on the hub to expand the hub. Afraid I might set up stresses in the spokes etc. which could be disastrous.
Post Number: 1079
Posted on Friday, October 16, 2009 - 09:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I usually don't pull them. As Dick says I use the press. On a Palmer BH I drilled 2 3/8 holes near the hub and made backup plates to go on the back to make sure I didn't break anything using a puller.
kerrigan
Username: kerrigan
Post Number: 32
Posted on Friday, October 16, 2009 - 10:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks fellows. My questions were academic. I can't imagine anyone wanting or needing to pull a flywheel while adrift as implied in the Crane Puller ad. My Palmer BH has two tapped holes through the flywheel near the hub but very little space behind the flywheel to insert anything. The need to remove flywheels seems remote anyway. I have several pullers of different sizes and configurations. They are mighty handy tools. I haven't smashed one yet.
Post Number: 303
Posted on Friday, October 16, 2009 - 03:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am sure it is much easier to pull a 5 year old flywheel off an engine than a 105 year old flywheel. And, I bet the boat market was a small part of their business, after all, a good farm engine has twice as many flywheels to pull.
Post Number: 2229
Posted on Friday, October 23, 2009 - 01:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Boat magazine ad 1919
c19
