Spark Plugs
Old Marine Engine » One and Two Cylinder Gas Inboards » Spark Plugs « Previous Next »
chris_spring
Username: chris_spring
Post Number: 165
Posted on Wednesday, October 27, 2021 - 12:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The Adams uses a Champion 25. The St.Lawrence uses an Autolite 3095 which, should be interchangeable with the Champion 25. For some reason it is not, but that's another story.
Is there a hotter plug than than the Champion 25 that I could try in the Adams?
Cheers!
narrabay2
Username: narrabay2
Post Number: 219
Posted on Thursday, October 28, 2021 - 06:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie feels Champion are not great. Might be the brand? Are todays Champions the same ones as years ago from a design and materials standpoint? Easier to try other brands (compatible number) than figure that out... my 2 cents
chris_spring
Post Number: 166
Posted on Thursday, October 28, 2021 - 07:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Interesting. I had an uncle that was in the auto repair business for years. He was never a fan of Champion.
Cheers!
Post Number: 2664
Posted on Wednesday, November 03, 2021 - 11:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The new Champion plugs have virtually NO glazing on the insulated electrode on the combustion chamber side. Compare a new one to a good clean old one. Old meaning from "way back when". The new one is a mat finish which to me is porous and once fouled is almost if not impossible to get clean.
