Offset engine
Old Marine Engine » One and Two Cylinder Gas Inboards » Offset engine « Previous Next »
bcm
Username: bcm
Post Number: 10
Posted on Monday, November 15, 2010 - 07:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
johnoxley
Username: johnoxley
Post Number: 12
Posted on Monday, November 15, 2010 - 11:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks like a Desaxe engine
See http://en.wikipedia.org/wiki/index.html?curid=24608799
Changes thrust on piston sidewall and alters durations of strokes.
larry_from_maryland
Username: larry_from_maryland
Post Number: 439
Posted on Tuesday, November 16, 2010 - 07:38 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The old 2 cylinder Deere engines were offset like that only the pistons were horizontial.
johnny
Username: johnny
Post Number: 366
Posted on Tuesday, November 16, 2010 - 08:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Detroit Engine Works sold a 8hp 4 cycle horizontal stationary desaxe engine.
Post Number: 2479
Posted on Tuesday, November 16, 2010 - 08:39 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This little engine was one of the more obvious of the offset engines, in other 1907 ads the company claimed 20 to 40 percent less cylinder friction ? I will look but I believe Ferro engines were offset.
R07
In the early 1960's Chrysler Corp had a racing division and would recommend tips to get better performance from their V/8s, on drag strip use they suggested reversing the pistons on the rods, they were offset to quiet the engines but resulted in friction ? Lots of piston slap but they did seem to run quicker.
Post Number: 2480
Posted on Tuesday, November 16, 2010 - 09:00 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
1909
Ferro Machine & Foundry Company
F1
F2
Post Number: 1291
Posted on Tuesday, November 16, 2010 - 11:57 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The automotive industry still does this. However it us usually done be offsetting the wrist pin in the piston. Not by moving the actual cylinder bore off to one side
rbprice
Username: rbprice
Post Number: 344
Posted on Saturday, November 20, 2010 - 08:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Not only did Ferro do that on their smaller and earlier engines, but my 1920 four cylinder, four cycle is also offset. Approx. .63 inch.
