J.B.'s Line boring and machining oper...
Old Marine Engine » One and Two Cylinder Gas Inboards » J.B.'s Line boring and machining operation « Previous Next »
Post Number: 1122
Posted on Thursday, May 25, 2006 - 01:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
J.B.'s Machining photos
#1 gasket template for 4 and 8hp L-A. Can cut many thin and thick gaskets at one time.
J1
#2 push rod sharpened To "fish mouth" , cuts holes without tearing gasket.
J2
#3 finished gaskets
J3
#4 boring jig, four 3/4" bolts cut 1/4" short of base, drilled and tapped for 3/8" bolts, welded to plates bolted to tool carrige. Oversize holes in plates and 3/8" bolts in 1/2" base holes all allow for latterel movment. Vertical alignment is done with the 3/4" nuts, the 3/8" bolts lock the base down.
4
#5 Gauge for setting tool depth and seal. My lathe has a short bed, tool had to be moved for each bearing. I bored a piece of stock to fit the boring shaft, counter bored one side 1 3/8" for the bearing, other side 1 3/4" for the seal. The tool was split in half so it could be held over the shaft , the cutting tool is spring loaded, pops up to the tool.
J5
#6 Tool in place, setting cutter, it's concentric to the shaft so you don't have to feel for a high spot.
J6
#7 Cutting tool. I first tried sharpening the tool like a lathe cutting bit. Babbit kept piling up on the tool. I then sharpened the tool at a 45 degree angle, it pulls the fillings out of the way, you can see the strings in the base.
J7
#8 I brought my stop against the tool carrige, left loose to slide. As I bored in, I would stop and back out to clear the cuttings, return to just shy of the stop, engage carriage and resume cutting. In a blind hole you have no way of seeing where you stopped.
8
#9 Counter bore for the seal and finshed bearings
J9
#10 Finished bore
J10
Post Number: 128
Posted on Thursday, May 25, 2006 - 07:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for taking the time to post them Richard. This case is for a Nadler 8hp, same as a Lockwood- Ash. This is a popular engine in our area, that's why I have the templates and jigs. The bearings in this case were poured too thick and out of plane, against a worn crank. Since there was enough material I line bored them to the standard bore. Bob Legnon had a crank that he had built up and reground. This motor will be run in a boat, the seals keep it much cleaner. Bob does this on all his motors.
Post Number: 230
Posted on Friday, May 26, 2006 - 12:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
JB - this has convinced me that I MUST visit with you folks next year . . . .miro
ps I have not forgotten about Dick G's propeller question
Post Number: 130
Posted on Friday, May 26, 2006 - 01:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Miro, will be looking forward to your vist, maybe we can plan some technical stuff. I brought my old digital camera to the shop, I'll take some pictures of other operations, have to pour some rod bearings soon. Richard said he'd be glad to post them.
paulgray
Username: paulgray
Post Number: 25
Posted on Friday, May 26, 2006 - 06:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
JB- Nice work on the bearings- Reminds me of using an old KW boring setup on a couple of model T blocks. I ended up taking several light cuts. The cutter has a screw feed to move it out radially. Since the shaft was 1.000" I would insert gauge pins between the shaft and the bearing shell to measure the overall diameter after each pass and sneak up on the final dimension.. Then I would hike out the cutter a bit each time until I got it right size. Your gasket hole cutters are a nice design- will file that away for future use. Thanks for sharing the pix.
Paul }
rbprice
Username: rbprice
Post Number: 196
Posted on Saturday, May 27, 2006 - 11:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
JB - Miro and I are going to rent a Lear Jet and come down together in March.
Bob
