Rust coming out of Exhaust, PW 27
Old Marine Engine » One and Two Cylinder Gas Inboards » Rust coming out of Exhaust, PW 27 « Previous Next »
cbuzzyb
Username: cbuzzyb
Posted on Saturday, August 27, 2011 - 11:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I Have a Palmer PW 27 that is raw water cooled in salt water. I recently replaced the top half of the engine (cylinder and head) with a unit that was used in a fresh water lake. The original engine's cylinder and two heads corroded away in a 25 year period. I also installed a fresh water reservoir to flush the engine after use. Recently I ran the engine after about a month and rust came out of the exhaust for about a minute. I am thinking I should not do the freshwater flush and just keep saltwater in the engine. Any suggestions?
laurie_d
Username: laurie_d
Post Number: 109
Posted on Sunday, August 28, 2011 - 06:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
cbuzzyb, Not sure if you have been following the discussion in the last few days about closed systems for Blaxlands but one very good suggestion shown in that is to run some engine coolant in your motor when you flush it. I'd also consider leaving that coolant in the motor rather than letting it run dry with the flushing. To be environmnetally responsible you should flush it again with fresh water before running it in the Lake or wherever taking care to retain as much of the coolant as you can. Regards
richardday
Post Number: 987
Posted on Monday, August 29, 2011 - 02:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Leaving salt water in a cast iron water jacket is simply slowly destroying the engine. Flush it well after every salt water exposure and don't let any of the cast iron water jacket dry out as the salt in the iron will expand and destroy the castings. For the winter fill the water jacket with auto antifreeze and drain it off in the spring. Smart thing to do is make up a simple keel cooler and run 50% antifreeze and fresh water in the water jackets portions of the engine. Then you don't have to drain the coolant in the winter.
