Wilcox
Old Marine Engine » One and Two Cylinder Gas Inboards » Wilcox « Previous Next »
searcher
Username: searcher
Post Number: 505
Posted on Friday, December 09, 2011 - 12:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There is an interesting old engine on eBay right now. It is a Wilcox McKim Saginaw, Mich. The eBay number is 230710634925
searcher
Username: searcher
Post Number: 506
Posted on Friday, December 09, 2011 - 12:41 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Same seller also has an interesting timer and a Red Wing single cylinder up for bid.
Post Number: 1454
Posted on Friday, December 09, 2011 - 08:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks like it started life as an outboad at least that is my guess
Post Number: 2701
Posted on Friday, December 09, 2011 - 09:15 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Searcher
I saw this on ebay the other day and was looking at the timer and of course curious as to what eng it might fit when I saw this photo and the two words "Huilez Souvent" Ah-Ha that will help with a name ??
HS
Put it in my translator and in French it means "Oil Often" I then noticed the arrow and small hole----- so much for that detective work !!
