Waterman K1
Old Marine Engine » One and Two Cylinder Gas Inboards » Waterman K1 « Previous Next »
mLoutboards
Posted on Tuesday, January 17, 2012 - 04:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Interested in any and all info pertaining to this Waterman K1 (completeness, rarity, value, overall condition etc. etc.)
Any help is greatly appreciated!
http://i285.photobucket.com/albums/ll66/mloutboards/IMG_0556.jpg
http://i285.photobucket.com/albums/ll66/mloutboards/IMG_0555.jpg
http://i285.photobucket.com/albums/ll66/mloutboards/IMG_0554.jpg
http://i285.photobucket.com/albums/ll66/mloutboards/IMG_0553.jpg
http://i285.photobucket.com/albums/ll66/mloutboards/IMG_0557.jpg
qwilkin
Username: qwilkin
Post Number: 54
Posted on Tuesday, January 17, 2012 - 06:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
How does one clean brass equipment by saoking .
I received a brass piece of an engine that had been overhauled and CAME BACK AS CLEAN AS A WHISLTE OVBIOUSLY SOAKE IN SOMETHING
CAN ANYONE HELP
QUINTON
senojn
Username: senojn
Post Number: 91
Posted on Wednesday, January 18, 2012 - 03:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Quinton you are in the wrong area for such a question .
You can safely use household brown vinegar .
Or carefully use hydrochloric acid .
Rinse in clean water and apply car wax or brass protector.
kerrigan
Username: kerrigan
Post Number: 43
Posted on Wednesday, January 18, 2012 - 06:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Muriatic acid is also effective for cleaning brass. It may be more readily available and less expensive than hydrochloric acid. It's used to condition swimming pool water. Dilute with water. Be careful.
scott_n
Username: scott_n
Post Number: 214
Posted on Thursday, January 19, 2012 - 09:46 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Nice Waterman looks like a early one but the mixer looks like it came off a small hercules
silverghost
Username: silverghost
Post Number: 29
Posted on Friday, January 20, 2012 - 03:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Watch any of these strong acids when cleaning corrosion off of old brass.
Don't let it sit on the brass very long.
Strong acids will quickly eat up the zinc in the brass turnng it from that gold color we all like to a copper color.
After all~
Brass is mostly a mixture of copper & zinc with a few trace elements mixed-in depending on the type of brass alloy.
Bronze is a mixture of copper & tin with additional trace elements mixed-in depending of the bronze alloy type...
