Detroit Family
Old Marine Engine » One and Two Cylinder Gas Inboards » Detroit Family « Previous Next »
Post Number: 1560
Posted on Monday, September 03, 2012 - 04:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This landed in my shop today.
Thanks Debbie and Randy
Timer is very nicly fabricated and uses a set of car points that close for just an instant so the car coil works good. The button on the top of the timer is a kill switch.
It looks like it had an exhaust box muffler at one time.
Note the 3 bolt water pump flange and it doesn't use the traditional Detroit water pump strap.
It had a fabricated check valve and a carb from an outboard. However the carb wasn't any good so I replaced it with a check valve James Compact carb.
Before
After
Post Number: 1561
Posted on Monday, September 03, 2012 - 04:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You tube vids
click here
click here
john_archibald
Username: john_archibald
Post Number: 182
Posted on Monday, September 03, 2012 - 05:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
We don't get meteorites like that around here, but I wish we did.
Archibald
Northfield, Minesota
Post Number: 721
Posted on Monday, September 03, 2012 - 06:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie, Jamie has a motor with a pump mount like this, if he see's this I'm sure he'll ID it.
Post Number: 2892
Posted on Monday, September 03, 2012 - 08:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The engine is a Gile Boat & Engine Co.of Ludington,Michigan !
1904-05 William L. Gile patented a marine engine
and invented reversible propellers and carburetors, in 1907 he sold his Co. and all its tooling To C.T.Wright in Greenville, Michigan and was plant superintendant,Gile left the company in 1908 and opened a new enterprise in 1909 the Gile Boat & Engine Co. in Ludington, his engine mfgring rights stayed with C.T.Wright so the new company bought Detroit Marine engines and made some changes such as the water/pump and mount !Gile sold his interests again in 1916 to Stearns Motor Mfging Co. I don't know if Stearns actually continued supplying the basic Detroit two cycle engines- if so I haven't seen one yet ?
Post Number: 2893
Posted on Monday, September 03, 2012 - 08:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
1912
g12
Post Number: 1562
Posted on Tuesday, September 04, 2012 - 07:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Richard
Post Number: 1563
Posted on Tuesday, September 04, 2012 - 06:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Cooling system even works
Ran it for over an hour today
click here
Post Number: 2894
Posted on Wednesday, September 05, 2012 - 12:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
"Beguiled" by a "Gile"
