BMM Britannia Stalwart
Old Marine Engine » One and Two Cylinder Gas Inboards » BMM Britannia Stalwart « Previous Next »
dave_wheatley
Username: dave_wheatley
Posted on Monday, March 05, 2012 - 07:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Just acquired this engine, probably built 1930's
Single cylinder side valve. Magneto ignition. Guessing at about 5 hp.
It looks as if it will run.
Has anybody got information on this?
BMM = British Motorboat Manufacturing Co.
Thanks, Dave
jima
Username: jima
Posted on Monday, February 18, 2013 - 12:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have recently bought a Brittania Stalwart Type SM1 Serial No, 4053. Solex 26 MHD Carb. BTH magneto,sounds similar to yours. Havent been able to get any manual or info. so I presume they are scarce. Mine is almost a runner, just needs more tinkering. Jim.
dave_wheatley
Posted on Monday, February 18, 2013 - 03:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello Jim,
Thanks for the reply. Mine has a Wico mag which is gear driven. Somebody has welded the gear on the mag, and I think the coil is caput, so I did spend a bit time trying to get a coil at a reasonable price with no luck. Your post here has got me going again!
I think mine will run if I can get the mag sorted.
I'll check the s/n and the carb type.
Where are you?
Dave
jima
Username: jima
Posted on Monday, February 18, 2013 - 06:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Dave,
Thanks for the prompt reply.I live in Fife in Scotland. Ive tried everywhere for a manual but so far nothing. My next move is to send pics to Patrick Knight. The drive for the mag on mine is a cam on the end of the camshaft which flicks the mag.I had one of these engines previously and the mag was gear driven.If you have my email address, can you get in touch and I will send pictures. Regards, Jim.}
dave_wheatley
Posted on Saturday, February 23, 2013 - 09:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello Jim,
I'm near Stranraer. I'll try to get some pictures and post them here.
Bloody cold here at the moment!
Dave
dave_wheatley
Posted on Saturday, February 23, 2013 - 12:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here's some pics. Hope they are of use.
DaveStalwart1Stalwart2Stalwart3
jima
Username: jima
Posted on Friday, March 01, 2013 - 05:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Dave, I cant seem to be able to attach my pictures. Let me have your email address or phone number and I will send them to you direct. Please how many teeth are on the drive gear for the magneto and the number of teeth on the gear attached to the magneto. Jim.
nev_b
Username: nev_b
Posted on Saturday, March 21, 2015 - 02:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
http://[URL=http://s234.photobucket
This is the engine I bought last week, does anyone know if it's possible to date these engines
nev_b
Username: nev_b
Posted on Saturday, March 21, 2015 - 02:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Oops sorry no picture, I will try again
