New Caille
Old Marine Engine » One and Two Cylinder Gas Inboards » New Caille « Previous Next »
alaskanrocket
Username: alaskanrocket
Posted on Tuesday, September 01, 2015 - 03:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have recently acquired a Caille single cylinder. Its in really good shape but missing a couple of items. I still need to track down a timer assy. and water pump. I think the timer assy would be easy enough to fabricate but the water pump casting could be a big hurdle. I would also like to find someone who would be willing to lend me the crankcase cover plate to use as a mold or if I sent them the materials to make me a mold then I could cast one. I'll update photos as my progress occurs. Please let me know if anyone may have some leads on parts. Thanks, Jess
I'm working on trying to figure out how to shrink my photos so they will fit, ill post them when I do.
Post Number: 2125
Posted on Tuesday, September 01, 2015 - 04:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I may have a water pump.
Send me pics with aprox dimensions so I can see if what I have is what you need
I can post your pics for you as well.
Hope this helps
alaskanrocket
Posted on Tuesday, September 01, 2015 - 04:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie, I sent you an e-mail
Post Number: 2126
Posted on Wednesday, September 02, 2015 - 12:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Tim's pics
The last one is what his will look like once he is done with it.
I have a pump and will send you an e-mail.
alaskanrocket
Posted on Wednesday, September 02, 2015 - 03:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Awesome! Thanks.
alaskanrocket
Posted on Thursday, September 10, 2015 - 11:21 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Could somebody give me outside diameter of the eccentric, and the shaft center to eccentric offset. Thanks, Jess
Post Number: 1092
Posted on Thursday, September 10, 2015 - 10:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Easiest thing would be to measure pump stroke, offset would be half of that. I have castings for Lockwood Ash eccentrics, very similar if you want to try one, have the eccentric straps also.
