Inboard That's Outboard
Old Marine Engine » One and Two Cylinder Gas Inboards » Inboard That's Outboard « Previous Next »
Post Number: 3718
Posted on Monday, November 23, 2015 - 01:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Inboard That's Outboard ?
iout4
bruce
Username: bruce
Post Number: 514
Posted on Monday, November 23, 2015 - 04:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Clarke-troller prototype....ish
solarrog
Username: solarrog
Post Number: 609
Posted on Monday, November 23, 2015 - 07:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
first little splash its a rowboat
Roger
foxman
Username: foxman
Post Number: 7
Posted on Friday, December 04, 2015 - 06:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Third type of marine propulsion. Inboard,outboard, now the overboard motor. Harry(?) Miller of Miller racing engines supposedly built a four cylinder in this configuration, but it never went past a prototype (or a pssing fancy with a drawing)
david_doyle
Username: david_doyle
Post Number: 45
Posted on Friday, December 04, 2015 - 09:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have always thought that this configuration never got it's due. Puts the weight where it should be (low), removes the cooling system, reduces shaft lengths etc.
I guess there are some challenges with moving intake mixture and spark? Some other challenges with making adjustments while under way? Guess you also need to have a pretty high level of confidence in ALL your gaskets. OK just talked myself out of admiration LOL.
