Waterman Engine help
Old Marine Engine » One and Two Cylinder Gas Inboards » Waterman Engine help « Previous Next »
bradstubenrauch
Posted on Monday, July 04, 2016 - 02:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone have info or knowledge regarding this engine? The timer and waterpump are integral. The nameplate is on the timer cap. It is marked Waterman Model A, 4HP, Serial 291. I am trying find the year built as well as what carb was used. Any help would be great.
bstub
Username: bstub
Posted on Monday, July 04, 2016 - 02:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here are some pictures of the Waterman Model A engine I am looking for info on. I appologize for the pics. I have the piston soaking in order to get unstuck. Timer Cap/NameplateWaterpump/TimerConnecting Rod. Cylinder upside down
robert
Username: robert
Post Number: 713
Posted on Sunday, July 10, 2016 - 12:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Would this be one of those fateful cylinders in which if the piston is pushed in too far the rings pop out over the lip at the top of the cylinder walls making the piston impossible to remove (in one piece)?
