if you had to guess,
Old Marine Engine » One and Two Cylinder Gas Inboards » if you had to guess, « Previous Next »
Bill Schaller
Posted on Monday, March 04, 2002 - 08:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
do you think the lever is for a reversable prop?
Text description
Posted on Monday, March 04, 2002 - 08:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I would guess that is the purpose.
Posted on Monday, March 04, 2002 - 09:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bill,
I would agree that the lever is for a variable pitch prop. What engine is that? I have an engine with a similar valve chamber configuration that I cannot identify.
Thanks.
Andrew
bill
Posted on Monday, March 04, 2002 - 11:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Text description
2 hp westman. When we talked, this is the engine I wanted to know what size reversable prop it would take.
bill
Posted on Monday, March 04, 2002 - 11:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Text description
Text description
