Lunkenheimer mixer part wanted
Old Marine Engine » One and Two Cylinder Gas Inboards » Lunkenheimer mixer part wanted « Previous Next »
dick_briggs
Username: dick_briggs
Post Number: 39
Posted on Friday, December 25, 2020 - 03:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am looking for a source of a cast brass handle for the stem that controls the lift of the valve disk in a Lunkenheimer mixer, something similar to the picture below, around 1.25" diameter. Any thoughts appreciated. Thank you, Dick Briggs
bartropr
Username: bartropr
Post Number: 103
Posted on Monday, December 28, 2020 - 09:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have seen similar things to these in the UK in model engineering supply catalogues/ on their web sites? Suppliers of model traction and railway engines/locos
dick
Username: dick
Post Number: 43
Posted on Monday, December 28, 2020 - 10:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank you. I have been offered a cast iron one which will work just fine, but I need two so I will check for some of those sites. Best, Dick
