Chapman Super Pup 4 1/4 HP problems
Old Marine Engine » One and Two Cylinder Gas Inboards » Chapman Super Pup 4 1/4 HP problems « Previous Next »
Moderator
Username: andrew
Post Number: 567
Posted on Sunday, February 26, 2006 - 10:43 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The following came in by email. I will direct Brian here for followup:
quote:
Hi
We have restored a Chapman Super Pup 4 1/4 HP engine and have a problem.
It would appear that the gears driving the magneto are incorrect and the magneto shaft rotates at twice engine speed.
Being a 2 stroke, this gives us ignition at BDC whcih causes an explosion of the incoming mixture as the transfer port is open.
How it got to have this gearing is a mystery. Do not know history of engine at all.
Is it possible to get the correct gears?
Would you know the specs of the correct gears in case we have to get them made up?
Any help would be appreciated.
Brian Taylor
[email protected]
Publicity Officer
Hervey Bay Historical Village & Museum
13 Zephyr St.
Scarness.
07-4124 6526
WebSite: http://herveybaymuseum.museum.com/welcome.html
richardday
Post Number: 298
Posted on Sunday, February 26, 2006 - 02:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Is the magneto correct for the engine?
peterogborne
Username: peterogborne
Post Number: 117
Posted on Sunday, February 26, 2006 - 05:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Brian........your Chapman Super Pup is OK. All to do with the "Bounce Start'' and probably the reversing by moving the magneto over TDC.
Brian Taylor
Posted on Sunday, February 26, 2006 - 07:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard
The magneto has the letters WN 3097 stamped on the flat area. Also the words Chapman Super Pup and a number,,,cannot read.
Sorry Peter, not sure that I understand your reply "your Chapman Super Pup is OK. All to do with the "Bounce Start'' and probably the reversing by moving the magneto over TDC."
jules
Username: jules
Post Number: 16
Posted on Monday, February 27, 2006 - 09:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think what Peter means is the magneto needs a little adjustment, you may need to swing the magneto 180 degrees or adjust a little to the left/right
gregoryan
Username: gregoryan
Post Number: 10
Posted on Thursday, June 08, 2006 - 08:48 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
THey ARE MEANT to have the mag driven at 1:2 gearing, it is how the get away without having the 'impulse' spring! Yes there is a wasted spark.
