Barber bros.
Old Marine Engine » One and Two Cylinder Gas Inboards » Barber bros. « Previous Next »
B pineo
Posted on Monday, November 17, 2008 - 10:00 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have recently found a very small and early Barber Bros. canoe engine. It has been abused, and I would like to find a doner engine. The block is perfect, however the rod has been lost. Any thoughts? I will try to post pics soon.
Post Number: 415
Posted on Monday, November 17, 2008 - 08:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The connecting rod can be fabricated, lots of options. It could be cut out of aluminum, the bearing turned from bronze stock, split and clamped inside the aluminum. Welded steel will work fine, could be bolted to a brass block like a steam engine.
bruce
Username: bruce
Post Number: 186
Posted on Tuesday, November 18, 2008 - 07:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Any chance you might post a couple photo's of your Barber canoe engine?? I may have a duplicate to your canoe engine complete-is the block aluminum?
brandon p
Posted on Wednesday, November 19, 2008 - 02:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bruce, I will post on friday eve. when I go to the shop. The block I have is basically a miniaturized Lathrop like those in the teens/twentis. It is cast iron. What does yours look like?
