Easthope Parts?
Old Marine Engine » One and Two Cylinder Gas Inboards » Easthope Parts? « Previous Next »
john_y
Username: john_y
Posted on Thursday, July 05, 2007 - 04:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am looking for a cylinder head for a 10-14 Easthope, and was wondering if anybody might have some leads? Is Joe Holmes still active on this board?
I would like to add that I have lurked here for some time, and would like to thank all the folks who share there knowlege and experiences of these great old engines.
joe_h
Username: joe_h
Post Number: 11
Posted on Monday, July 09, 2007 - 12:01 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello John, Joe is at [email protected]. You still working on VA4893 10-14 Easthope?
john_y
Username: john_y
Posted on Tuesday, July 10, 2007 - 03:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Joe, I have sent you an e-mail. Yes, I am still working on that old "Babbit Thrasher"
grdmcnl
Username: grdmcnl
Posted on Monday, March 23, 2009 - 12:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
joe,looking for a head for a 4h.p.easthope #j2749
joe_h
Username: joe_h
Post Number: 22
Posted on Monday, March 23, 2009 - 03:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello Gordon....some new heads were recently made from original patterns and available for $185.00. These heads have not been machined. If you have the original head you may be able to salvage the valve guides. If not I have nos guides, also unmachined. I also have valve springs...........Joe
grdmcnl
Username: grdmcnl
Posted on Monday, March 23, 2009 - 06:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
joe i have the old head which has a bad crack across the face is there a place to repair this
joe_h
Username: joe_h
Post Number: 23
Posted on Monday, March 23, 2009 - 07:41 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Gordon....cracks can be welded sometimes but probably not a good idea if you are going to use the engine in a boat. There is a lot going on when you try to weld repair a crack. As most of these engines were salt water cooled the head crack is likely a rust expansion problem which means a weld repair or an epoxy repair will not last as the rust tumour is still alive inside the head. There are places that do cast iron crack repairs but mostly auto parts that have not seen salt water. They are reluctant to take on a repair such as yours for many reasons, all of which point to lack of success. Your engine J2749 was built in 1936 and was bought by A. Linton and Co. Andy Linton was just down the street from Easthope and Turner Boat works. Andy Linton built mostly clinker construction and the records show the engine and boat went to a logging outfit somewhere in the Queen Charlotte Islands. Do you have the boat too? Do yourself and your engine a favour, get a new head and be happy that you can.............Joe
smegerhead
Username: smegerhead
Posted on Saturday, March 28, 2009 - 11:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Any interest in a Easthope 2hp
single cylinder (3 1/16) bore
6 November 1941.. only 42 made
s/n RA3976.
axtion_jim
Username: axtion_jim
Post Number: 8
Posted on Thursday, April 02, 2009 - 11:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Joe....tell us about the latest Easthope from Abbotsford. I new the previoust owner.I think it has now found a good home. Jim
joe_h
Username: joe_h
Post Number: 24
Posted on Friday, April 03, 2009 - 02:28 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Jim, It started with the post previous to yours which I answered. It was not a 2hp but a 7hp. It appeared complete but was rusted solid. The previous owner had passed away recently and friends were trying to handle his estate, hence the post. My records show that the owner John, had 4 engines, one of which was that 2hp. We could not find the other engines. It was later learned that John had a storage facility and the engines were probably in there. The Public Trusty got involved and apparently visited the storage facility to value the contents. He declared there was nothing of value and hired someone to haul it all away. It is not clear that the engines were in there but. You must know where the scrap yards are in Aldergrove/Abbotsford area....maybe we should have a look around!! Joe
axtion_jim
Post Number: 9
Posted on Wednesday, April 08, 2009 - 01:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Joe, I took some photos of the 7 hp on Sat. Has it left for the new home. If you need a hand give me a call, I`m not that busy. Jim
joe_h
Username: joe_h
Post Number: 25
Posted on Thursday, April 09, 2009 - 02:07 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Jim.....a couple of planks, some rollers, and a come-along and it is home. It looks like it might have not seen salt water but it has been sitting outside for some time but very restorable I think. I do appreciate your offer of help..............Joe
rowella
Username: rowella
Post Number: 7
Posted on Friday, April 10, 2009 - 08:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
On the subject of salt damaged heads.
If a new head is not available and pattern making and recasting not an option, can future damage after repairs are made be avoided by an electrolytic bath? Any opinions will be welcom.
Martin head
axtion_jim
Post Number: 10
Posted on Saturday, April 11, 2009 - 12:15 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Martin, I would suggest trying to locate an other head. Welding the head back together is an exercise in futility. There is a fellow who has a father that is a chemist, and some where on this old engine site theirs a write-up on this problem. I don`t think that they have found the total cure for the problem.Something to do with a chemical that is suppose to react on the salt.I have a copy of it around,it`s just not handy. Best I can do for now. Jim
rowella
Username: rowella
Post Number: 8
Posted on Sunday, April 12, 2009 - 06:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for that Jim, unfortunately getting an other head is not possible for this model.
Has anybody had any success with electrolytic or other chemical treatment?
axtion_jim
Post Number: 11
Posted on Wednesday, April 15, 2009 - 11:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Martin,go the misalanious section on this site. Mark has made a interesting bit of info. I believe the last entry was form Richard Day, Poke around and it will come up........Jim
joe_h
Username: joe_h
Post Number: 28
Posted on Thursday, April 16, 2009 - 03:40 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Martin, I have a friend that has had some success derusting and desalting inside water jacketed parts by heating them red hot in a fire pit and gently cooling the part. The electrolytic process would be very difficult if not impossible on the interior of a small part such as yours as the anode (or is it cathode) has to see the surfaces that are affected and without touching the metal.
rowella
Username: rowella
Post Number: 9
Posted on Thursday, April 16, 2009 - 05:39 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks jim and joe for the good info martin.
