4-40 gray marine engine parts
Old Marine Engine » Multi Cylinder Gas Inboards » 4-40 gray marine engine parts « Previous Next »
fcook
Username: fcook
Posted on Sunday, January 15, 2006 - 09:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am about to start the restoration of a 4-40 Gray Marine engine. It was salvaged from a johnson rear engine run-about with a vdrive setup. I estimate the year of the boat to have been mid 1920's. I am sure it is only the begining but I need a distributer cap, pionts and a condenser. Anyone have a source for parts?
Moderator
Username: andrew
Post Number: 1333
Posted on Monday, January 16, 2006 - 08:43 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
fcook,
The Maintenance Handbook sold on the marineengine.com site will cover that engine.
For parts you could try Duby Marine in NY, 716-694-0922
fcook
Username: fcook
Posted on Monday, January 16, 2006 - 12:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks, I will try both
regila
Username: regila
Posted on Tuesday, February 07, 2006 - 08:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
They can help me? I have a motor ailsa gray LB-4. Four cylinders, to gasoline. Where I can look for the technical characteristics. This motor this within the motors gray whose manual of maintenance this on sale? Thank you very much by its aid.
