Water hose
Old Marine Engine » Multi Cylinder Gas Inboards » Water hose « Previous Next »
spindrift
Username: spindrift
Posted on Sunday, June 27, 2010 - 09:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I want to replace the 3/4 inch water hose on my 327 fire ball gray , can I use automotive water hose they have at napa
ldobbins
Username: ldobbins
Post Number: 56
Posted on Monday, June 28, 2010 - 02:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Greetings Spindrift,
You can use a good quality automotive water hose from a parts store for much of the plumbing on your boat. But, be advised that the hose you purchase from an auto store is built for pressure systems and often may not hold up to the vacuum that may be created on the suction of intake side of your water pump.
A marine grade water hose may be purchased from most any reputable boat parts dealers or chains.
Cheers,
Lew "The West Coast Sterling Guy"
spindrift
Username: spindrift
Posted on Monday, June 28, 2010 - 04:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks, sounds Like I should by marine for the intake so it will not collapse and then I could use good automotive for the rest.
