Chrysler Crown valves
Old Marine Engine » Multi Cylinder Gas Inboards » Chrysler Crown valves « Previous Next »
jamesosler
Posted on Thursday, June 04, 2009 - 07:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Stuck valve which is the exhaust one. looking for ideas to free it up.
ldobbins
Username: ldobbins
Post Number: 46
Posted on Saturday, June 06, 2009 - 12:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If the engine has been a runner and the valve ceased, you may not be running an oil with enough sulphur or other lubricating properties. As the sulphur is being removed from most of our oils, we are seeing a rash of sticking valves especially in flat head engines.
You may be able to remove the spark plug and if the exhaust valve is open, spray a little penetrating fluid at the valve and stem. likewise from the bottom side of the guide from the tappet cover access. Give it some time.
If this frees the valve, get an additive for your oil or make sure you change to an oil with sulphur or an adequate replacement. Delo 400 30 WT oil has always been good until now. If you can find a supplier that has some that has been around for a while, it may still contain sulphur. There are several other good oils for these engines too, some synthetics also.
If this was not a runner and is out of the boat, get a hammer!
Cheers,
Lew
"The West Coast Sterling Guy"
