First US Marine V8/Straight 8
Old Marine Engine » Multi Cylinder Gas Inboards » First US Marine V8/Straight 8 « Previous Next »
bud_tierney
Username: bud_tierney
Post Number: 69
Posted on Friday, October 06, 2017 - 12:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
While I've never gotten into marine engines, I've always assumed multi-cyl development was considerably ahead of automotive...recently found:
Jan 1910 trade journal announcements of a new Buffalo V8...
May 1908 squib thaat John Kowalski building a 40-footer, powered by an 8 cyl 6x6, presumably his own...
What do the old marine engine history books give as the first US marine V8s/straight 8s??
Many thxx for any comments.
Post Number: 4041
Posted on Friday, October 06, 2017 - 03:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bud
Not sure that the first 8 or V/8 marine eng info
is available in the few publications on marine engs ! its a rather specific detail I,m sure that is arguable among the many. if technical history books were in data base form and that specific info was entered it would be a fairly simple task to sort out, I don't know if any exist ?
I have probably 10 or more listings in my data base, but in the early days I was concerned with
names of Marine Engine Manufacturers and only started the detailed info much later. so a lot to yet discover and record !
I was on this page when I read your post--
1915
s1
s2
s3
I have seen the Buffalo ad, I'll post it when I can find it .
bud_tierney
Post Number: 70
Posted on Saturday, October 07, 2017 - 02:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard: As usual, the font of all wisdom on marine engines...
Many thxx!!! Will dig around in Sterling history...
Oddly enough, I'd also just run across an announcement of a Sterling Light Car engine in both OHV (model 8, unit power plant) and L-hd (model 11, engine only) versions...
A 23/4 x 4 4Cyl inline,it's in the Carette journal, Nov 1914 pg---oops---not all page #s copied, but it's between pgs 24 and 45 somewhere, probably text as my note says some specs included.
1913-14 period was the heyday of the Cyclecars, and in-between types called Light Cars...
bud_tierney
Post Number: 71
Posted on Monday, October 16, 2017 - 01:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Gave up on this; ran out of time...
Did run down at least one of Craigs "8s"---was two fours attached inline...
At least one of Godshalks "8s" turned out to be two fours in tandem...
Sterlings claim is probably to the first series production 8s; reportedly estab 1903, in Feb 03 H E L Trebert & Co were advertising 2, 4, 6 and 8 cyl verticals,,,
I'm assuming Treberts 8s were custon orders, as several of the period engine builders ads say "larger sizes made to order", or some such...
I did find a Buffalo ad that referred to their V8 under high speed engines, but made no real effort to find if it ever got into series producton...
