'56 Chriscraft Sportsman with K engin...
Old Marine Engine » Multi Cylinder Gas Inboards » '56 Chriscraft Sportsman with K engine electrical system « Previous Next »
Mark Cavin
Posted on Sunday, August 29, 2004 - 09:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm starting work on my K engine and found out that the original electrical system was 6V. The part numbers for the existing electrical system are:
Starter:Autolite MCL6004 1K
Generator:Autolite GEO 4807-3 3K
Distributor: Autolite 1AY 4009 9K
Coil: 12V 504 143
My question is why would the coil be labeled 12V? I hope I did the right thing by going to all the trouble to find a 6V battery. There was no battery in the boat when I got it. Regards, Mark
Bruce Decker
Posted on Friday, September 17, 2004 - 08:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mark -while not an expert, I do have a '56 Chris w/ 2 Ks, 6 volt. My understanding is that you could use a 12 volt coil, but better to get a 6 volt. The generator will not support a 12 volt battery so stick w/ the 6. NAPA still stocks 6 volt coils; if that doesn't pan out try a tractor repair store. Also, as for the battery, make sure you use the thickest battey cable you can find. 12 volt long cables will burn out especially if the ends are not squeeky clean. Sounds like this is your 1st classic boat - think about joining the Antique and Classic Boat Society chapter nearest your location. Contact them for chapter information at 315-686-2628 or www.acbs.org
Mark Cavin
Posted on Friday, September 24, 2004 - 07:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Bruce,
Gary responded to this thread on ACBS "How to" section. He thinks maybe the generator was rewound. Mark
http://acbs.org/discus/
