Watkins
Old Marine Engine » Multi Cylinder Gas Inboards » Watkins « Previous Next »
Posted on Thursday, November 01, 2001 - 11:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is a photo of a 4 cylinder Watkins restored by Paul Gray and displayed at the Calvert County Maritime Musuem show in spring 2001. The photo was taken and provide by Richard Durgee.
4cylwatright
4cylwatleft
Regards,
Andrew
ome
Bill Schaller
Posted on Friday, November 02, 2001 - 05:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Is that ignition correct, or did a later one get substituted?
Paul Gray
Posted on Tuesday, November 06, 2001 - 06:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bill-
I believe the ignition to be correct. It is a Unisparker distributor. Unfortunately, the guts of the distributor are missing. This engine belongs to a friend of mine, Harry Buck who purchased the engine many years ago. The porting on this one is strange with no apparent bypass porting. On the top picture, right hand jug, you'll see a small port (others taped shut)we are trying to figure out what goes on top of it.
Posted on Tuesday, November 06, 2001 - 09:01 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Paul: would like to figure the porting on this one
also! Do the ports from carbs open when piston is top dead center, and go into crankcase? do piston deflectors face away from these ports?
The open and taped ports go where??
Thanks Richard
Post Number: 628
Posted on Sunday, November 21, 2004 - 02:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Paul look at this patented "TWIN PORT" design,may be extra port on Watkins.
LTp
Post Number: 629
Posted on Sunday, November 21, 2004 - 03:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Leary Twin Port Motor
1913 ad,
Carb's on both sides of engine !
Post Number: 630
Posted on Sunday, November 21, 2004 - 03:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Leary TWin Port
L
solarrog
Username: solarrog
Post Number: 137
Posted on Sunday, November 21, 2004 - 03:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is the link to a picture of a Watkins single
http://albums.photo.epson.com/j/AlbumIndex?u=1659491&a=31500575&f=0
