Three Cylinder Frisbie
Old Marine Engine » Multi Cylinder Gas Inboards » Three Cylinder Frisbie « Previous Next »
kevin_stone
Username: kevin_stone
Post Number: 22
Posted on Thursday, February 25, 2010 - 08:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Poured two babbitt bearings for both ends of crankshaft with the help of good friend Lenny last night. Just thought others might be interested in seeing some pictures. Has turned into a big project and hope to have running for 2011 show season.
KevinBabbitt BearingsBabbitt Bearings
kevin_stone
Post Number: 23
Posted on Thursday, February 25, 2010 - 08:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here's a couple more pictures.
Post Number: 512
Posted on Friday, February 26, 2010 - 01:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Nice work, the bearing looks good. First time I,ve seen a sleeve type bearing made of babbitt, most are bronze.
kevin_stone
Post Number: 24
Posted on Friday, February 26, 2010 - 08:57 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks JB, Thats the original sleave in the first post and it has about 20 thousands play in it. It's also kind of soft, maybe has high lead. We used high tin based babbitt. Thats the base in the third picture to show what i'm working with and weights about 320lbs. Babbitt BearingsBabbitt BearingsBabbitt Bearings
