Volvo MD1 & 2
Old Marine Engine » Diesel Inboards » Volvo MD1 & 2 « Previous Next »
allatsea
Username: allatsea
Posted on Saturday, December 11, 2010 - 06:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello, new to this forum. I am just about to buy an old Westerly Cirrus but it has a seized MD1. The local mechanic says forget it as parts are unavailable. Is this correct, or (l hope) can l strip this old unit down and rebuild. Where can l get parts for these older units?
mygooma
Username: mygooma
Post Number: 8
Posted on Saturday, December 11, 2010 - 10:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Good luck with the MD1B. Parts are available from volvo but are expensive. Is the piston seized or the transmission? I have an MD1B and am still working on it. Only remaining problem is with the governor/fuel injection. I can't get it to idle satisfactorily. Where are you located? I will try to send the shop manual to you via separate e-mail. Good Luck, Mart G., Manahawkin NJ USA
oslin04
Username: oslin04
Post Number: 47
Posted on Saturday, December 11, 2010 - 11:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Allatsea,
Well parts are available for the MD 1 but they do take a bit more finding, but the MD 2 parts are freely available, although like any Volvo they are pricy, but you can pick up a running MD 2 engine for about £500 or £600 or less in good nick, I would advise you to do this as they give you more power and are smoother, I am a bit surprised you have an MD 1 in your boat as the standard was the MD 2 from Westerlys, if you do go this way try and get an MD 2C
Hope this helps
Keith Inglis. Marine Engineer
allatsea
Username: allatsea
Posted on Saturday, December 11, 2010 - 12:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone have a history of the Volvo engines, ie MD1, MD2 etc with horse power and dates. I keep seeing the MD reference but have no idea of the lineage? I would like to know about all the later versions.
matt_morehouse
Username: matt_morehouse
Post Number: 69
Posted on Saturday, December 11, 2010 - 02:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a list of specs for the Volvo MD series engines send me your fax number and I will send it. Also I have some parts.
baillie
Posted on Sunday, December 12, 2010 - 07:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am about to take out a MD1B from my boat, more or less everything works, I am only taking it out to replace it with a much lighter petrol engine to improve my ability to race in class. It would be a shame to break it up but I guess that most of the parts are common to the MD1 and MD2 ranges, eg it has a Dynastart, I have seen the price of a reconditioned one (expensive to say the least) so as long as I got a reasonable contribution I would be open to offers. I think I would be interested at a price which would be competitive with the one mentioned above obviously the advantage to you would be that you could drop it straight in either replacing the gearbox or not as the case might be.
