Volvo Penta MD-1 Parts for Rebuild?
Old Marine Engine » Diesel Inboards » Volvo Penta MD-1 Parts for Rebuild? « Previous Next »
CB Allen
Posted on Tuesday, July 02, 2013 - 02:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
We have an old Volvo Penta MD-1, Serial number 11981, and we are trying to do a complete rebuild for it: Main and rod bearings, new piston, new valve springs, oil pump, gaskets, etc. We've been searching on the web, but we haven't had much luck in locating parts. Anyone know a good source for parts and information? We would also like to find the year for our engine, but the Volvo Penta site doesn't go back further than the late '80's. Ours is old, but simple, and we'd like to put it back in service. Thanks for any help!
nobby
Username: nobby
Post Number: 26
Posted on Wednesday, July 03, 2013 - 09:41 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
www.marinepartsexpress.com
www.frenchcreekmarina.com
www.marinepartseurope.com this one tells you what is available/obsolete
www.crommarine.se
Parts are available from Volvo so in theory any Volvo Dealer should be able to help. There are pdf copies of the manual available on the web just google Volvo MD1 manual to find them.
Cheers
Nobby
jiggernaught
Username: jiggernaught
Posted on Tuesday, July 16, 2013 - 01:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I've tried frenchcreek and marinepartseurope, neither were of any help with info on the MD47, which I'm looking for parts (head/manifold gaskets)Volvo Can. could not help, only referred.
nobby
Username: nobby
Post Number: 27
Posted on Tuesday, July 16, 2013 - 06:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The MD47 as I understand it is pretty much obsolete for parts. I turned up this possibility but it was posted in 2001
http://lists.trawlering.com/pipermail/trawlers_lists.trawlering.com/2001-Februar y/029183.html
Gaskets can be made though either out of copper or in the case of exhaust manifolds graphite and will work fine. Also I recommend the following company for getting obsolete gaskets made, you send them the old one for a pattern and they make you a new one or you send a template with material specifics.
http://www.gasketstogo.com/
Cheers
Nobby
