Transmission fluid for Farymann K34??
Old Marine Engine » Diesel Inboards » Transmission fluid for Farymann K34?? « Previous Next »
cpaul
Username: cpaul
Posted on Wednesday, May 13, 2009 - 12:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi folks --
Sorry, mine is probably considered an antique engine, although it is 30 years old. I have a Farymann K34 in my sailboat, and am trying to figure out what to use for transmission fluid. Any help would be most appreciated. The fluid we removed was light amber (like gear oil), but I suspect that some sort of ATF should be used.
Thanks!Farymann K34
delhez
Posted on Wednesday, January 09, 2013 - 11:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
J'ai un moteur similaire.
Quelle est la puissance de ce moteur ?
Quelle huile faut-il utiliser ?
Quel mod�le d'h�lice conseiller ? ( mon voilier n'
acc�l�re plus au del� de 1000 t/m )
