Sole Mercedes 55Hp info - manual - pa...
Old Marine Engine » Diesel Inboards » Sole Mercedes 55Hp info - manual - parts - advice « Previous Next »
paulythefish
Username: paulythefish
Posted on Saturday, January 31, 2015 - 12:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi, My 70s launch has a Sole Daimler Benz 55Hp. I would like to find a manual and any info about these engines. Had a bad oil leak which I have fixed and now runs well and uses little oil. Also wonder about the gearbox attached (see stamp) and the Vdrive which has no identifying info and no dipstick. Seems to be running OK but a bit noisy. Woould like oil and grease the whole drive chain. What oil should I use and any advice much appreciated. Whats the best way to grease the Ujoint. Cant get a grease gun onto the nipple. Thanks Paul
Engine plateGearbox stampVdrive
nobby
Username: nobby
Post Number: 58
Posted on Saturday, January 31, 2015 - 06:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
http://www.motoren.ath.cx/menus/mercedes.php
Cheers
Nobby
