Lister Diesel Engines
Old Marine Engine » Diesel Inboards » Lister Diesel Engines « Previous Next »
hcorbin
Username: hcorbin
Posted on Wednesday, February 20, 2008 - 01:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have an old fishing boat with two cylinder Lister Diesel N. 3300544LT2A-02 15HP RPM3000 unit 4887LT2MG85.
Can anyone give me any info on this model? What sort of oil for engine, gearbox?
Regards
Hugh Corbin
bluecometk
Username: bluecometk
Posted on Sunday, March 16, 2008 - 03:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Go to the Lister engine forum they maybe able to help you. http://www.listerengine.com/ those guys know everything about Listers/listeroids/Lister Petters.
Good luck
Bluecometk
michael binder
Posted on Monday, June 16, 2008 - 12:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi,
I have a Lister FR3 and am looking for the service manual of this engine. Can anyone tell me how I can get one?
regards
michael binder
robert
Username: robert
Post Number: 218
Posted on Thursday, June 19, 2008 - 07:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You might try Sleeman & Hawkin in the UK, or contact "Listerdiesel" on the above site.
todd_vidgen
Username: todd_vidgen
Post Number: 48
Posted on Sunday, June 22, 2008 - 02:30 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Or try the "rock tractor shop" in Northen NSW Austraila
Or Legend Power Products, Toronto ,NSW ,Oz
bigblockpal
Posted on Sunday, July 13, 2008 - 08:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello,I have a Lister workshop manual for the
HR and HRW 2&3 CYLINDER DIESEL ENGINES by Hawker Siddeley 118 page.contact [email protected]
listerdiesel
Username: listerdiesel
Post Number: 25
Posted on Tuesday, October 07, 2008 - 04:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The Lister 4887LT2MG85 is an LT2.
4887 - serial number
LT - engine type
2 - number of cylinders
MG - Marine reduction gear
85 - year and build spec, that '8' might be wrong.
nickgrady
Posted on Tuesday, July 21, 2009 - 07:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i have a lister 4 cyl.fitted in a boat i think its a ha4. or hr4. its aircooled with a fan on port side elec.start no decompretion lever cant find any eng.nr.i need head to manifold gaskets,exaust.runs great but needs gaskets,any idea for parts
robert
Username: robert
Post Number: 286
Posted on Tuesday, July 21, 2009 - 09:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
www.gasketstogo.com
n.white
Posted on Thursday, October 28, 2010 - 05:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
will a lister fr3m engine replace a sr3 engine without having to change the position of the engine mounts
janawirri
Username: janawirri
Posted on Tuesday, October 11, 2011 - 08:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
my old cruiser Jessica from brooklyn nsw had a lister and was wondering if any body knows this boat and wot motor was in her as I need to repower an am looking for correct size engine
gregtops
Username: gregtops
Posted on Tuesday, October 11, 2011 - 08:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have you any photos of Jeessica Janawirri?
I have been on the central coast for many decades and often down at Brooklyn. SOmetimes i cant recognise a boat until i see the photo, then it all hits home
janawirri
Username: janawirri
Posted on Tuesday, October 11, 2011 - 09:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
yes but this wont let me upload them for some reason
bruce
Username: bruce
Post Number: 287
Posted on Tuesday, October 11, 2011 - 09:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Janawirri, E-mail them to site moderator and he will post them for you. They may well need to be reduced in order to post
jcp john pryor
Posted on Friday, December 02, 2011 - 08:18 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
my son has a narrow boat with i think has an lister ls3 engine which runs ok for about an hour then starts to smoke and losses power and deisel is found in the sump any ideas as to this happens would be gratfull.
solarrog
Username: solarrog
Post Number: 500
Posted on Friday, December 02, 2011 - 12:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Check the injector pump, I bet its leaking into the crankcase
cabosails
Username: cabosails
Posted on Friday, December 02, 2011 - 03:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm looking for a new or in very good shape 60-80 horsepower outboard engine for a 41' Coronado sailboat. I prefer Perkins, Yanmar or Volvo.
todd_vidgen
Post Number: 216
Posted on Sunday, December 04, 2011 - 03:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
each cylinder has its own injector pump which is
run off its own lobe on the cam shaft between the exhaust and inlet lobes,there is a fuel supply
line that links all three pumps.Each pumps fuel
delivery pipe runs up to the injector of each cylinder
between the two valve push rods.
Also the injector and fuel leak off line are inside the rocker cover.It is not uncommon for
one of the many unions in the fuel system to come
loose,and sometimes for a pipe to crack,or become
damaged,especially the leak off lines as they penetrate
the rocker covers and the rubber seal/support blocks often get out of position or lost when the
covers are removed.
Todd.
trevor alan smith
Posted on Friday, July 29, 2016 - 07:45 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi i have a lister sr3 can anyone tell me how the filter is removed out of the sump please
