Baltimore Mechanic recommendation
Old Marine Engine » Palmer Engine Co » Baltimore Mechanic recommendation « Previous Next »
saquinney
Username: saquinney
Posted on Tuesday, April 12, 2005 - 05:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My 1970 Seafarer 31 flooded out due to my stupidity by not closing the seacock for the raw water strainer last January. Sidney Smith from Smith Corp Marine stopped by my boat last weekend and in about 4 hours time Sid had my P60 purring like a kitten after being totally submerged in salt water. To anyone in the Baltimore area who may need help I would and do highly recommend him.
Prior to contacting Sid, I called a few marinas that either laughed at the Palmer or tried to sell me a new motor. Fortunately I am a shade tree mechanic and knew the motor was not ruined and just needed a little TLC. I posted a request on this board for a mechanic, Sid replied as well as Richard Day with transmission support. Thank you to everyone on this board for sharing their knowledge. I am sure my P60 will last many years as a result of Old Marine Engines.com and my new mechanic Sid.
RonStanton
Posted on Thursday, July 05, 2007 - 08:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm looking for a mechanic in the Stamford CT area to come out and get my mercruiser 165 straight 6 running. I forgot to take out the hull drain plug over the winter and the boat filled with water covering about 1/2 of the engine. There is now water in the oil and I can't get the starter to crank over...it just clicks. I just need to get it running...
Lawrence T Wolfe
Username: larry_from_maryland
Post Number: 253
Posted on Friday, July 06, 2007 - 12:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Your starter has water in it and it wont drain out. Get a rebuilt starter and change the oil,hopefully the distributor did not get water in it. If you have the chevy 292 the starter is relatively cheap and has 3 bolts that stick in from the bottem. My uncle did the same thing.
