P-60 shaft collar/coupler
Old Marine Engine » Palmer Engine Co » P-60 shaft collar/coupler « Previous Next »
Marlon Klasson
Posted on Saturday, May 05, 2007 - 08:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
While trying to remove the 7/8" shaft from the shaft coupler, the cast collar/coupler was broken. I am looking desperately for a replacement, as lift-in is May 13th. The coupler is 3 1/4" in diameter, with a three-bolt attachment to the engine, and two set screws and a 1/4" keyway to hold the shaft. Does anyone here have a spare or know where I can get a replacement?
Marlon
mklasson(at)sympatico.ca
Richard Shapiro
Username: mainesails
Post Number: 30
Posted on Monday, May 07, 2007 - 09:44 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I don't have a source for the coupler - as I don't know if they are standard or not. I just replaced the coupler on a diesel, and was able to order it from a Yanmar dealer.
I would take careful measurements, then check with places like Moyer Marine, Transatlantic Diesel and Mack Boring - if you have the measurements, they can see if they have anything that fits. They also may have a better suggestion for you.
I would try Moyer first. There's a significant chance that it is the same unit that came with the A4.
However, in the worst case scenario, a machine shop can create a new one for you. Just give them the parts of the old one. Unfortunately, it wouldn't be cheap.
