Spark plugs
Old Marine Engine » Palmer Engine Co » Spark plugs « Previous Next »
Matthew Wallace
Username: matt_wallace
Post Number: 8
Posted on Saturday, August 11, 2007 - 05:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hey there my palmer m 345 is currently running on champion 6 jc's my engine manual does not specify any type of plug only gap..I have some champion uj 6's in my box of spare parts could you tell me what plug should i be running and what gap you reccomend? thanks...P.S> I beleive the motor is a 1973..thanks Matt
Lawrence T Wolfe
Username: larry_from_maryland
Post Number: 262
Posted on Saturday, August 11, 2007 - 07:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The J6c is a copper core plug. The UJ6 is sort of a standard plug of the same heat range. My champion book lists a RJ12yc plug which is an extended tip plug thats about the same heat range and has a copper core and a resistor built in. J6 was probably the old recomedation.
Matthew Wallace
Post Number: 9
Posted on Sunday, August 12, 2007 - 10:26 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Larry......
