Re palmer p60 fuel economy
Old Marine Engine » Palmer Engine Co » Re palmer p60 fuel economy « Previous Next »
verbryck
Username: verbryck
Posted on Monday, June 20, 2005 - 11:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have talked to another palmer owner locally and he says you can expect to burn about two pints an hour, is this about right? I am trying to figure out how much gas to take on a 60 mile trip in case I need to motor all that way. Thanks George
eddie
Username: eddie
Post Number: 66
Posted on Tuesday, June 21, 2005 - 05:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I had an Ericson 32 with a P-60. At about 6.1 knots it would use about 8/10 of a gallon per hour. I had a discussion with another P-60 owner and I forgot exactly what he said but if I recall correctly it was similiar. I'm over 50 and in my life only about 3 people I've ever talked to were accurate about fuel economy, especially in their cars. You should do your own experimenting in any case if you need to figure out your range.
mainesails
Username: mainesails
Posted on Thursday, September 01, 2005 - 09:26 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I use about 3/4 gallon per hour at 1800rpm and 5.5 knots in a Morgan 281. This is a low throttle setting.
This is with a Paragon reversing gear, so the prop is driven at crankshaft speed.
If you assume about 1 gallon per hour for every 10 hp and check the torque/hp curve for your cruising rpm you'll be in the ballpark.
Karl Burton
Posted on Thursday, September 22, 2005 - 12:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I also have a Morgan 281 (23.5 foot LWL) and get very similar consumption to mainesails above. At about 6.5 knots it would be about 1.2 gals/hour.
eddie
Username: eddie
Post Number: 73
Posted on Monday, September 26, 2005 - 04:19 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Karl, I would get 8/10 gph with my Ericson 32 but only after throttling back from a top speed of 6.4 knots to about 6.2 knots. Wide open I would get closer to 1.2 - 1.3 gph. Backing off 1 - 2 tenths of a knot from top speed made that much difference.
