3 cylinder gray
Old Marine Engine » Gray Motor Co - early 1 and 2 cylinder » 3 cylinder gray « Previous Next »
Marc DeLeonardis
Posted on Friday, February 08, 2013 - 08:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Are there any of these out there?
Post Number: 766
Posted on Saturday, February 09, 2013 - 08:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
First one I've seen. The 3 cyl engine about half way down in the link below may be a Gray, different series.
http://www.oldmarineengine.com/discus/messages/3428/252671.html
Post Number: 1611
Posted on Saturday, February 09, 2013 - 09:15 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It is a 3 cylinder "T"
There are a few around however most of them are twins. There is a real nice single right here in my neighborhood.
Here is the pic again that I enhanced as good as the original pic quality would allow
Post Number: 2981
Posted on Saturday, February 09, 2013 - 03:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This post required more gymnastic photo management than most I've seen on this site ?
This is the only other Gray Model T triple that I am aware of, its in the Antique Boat Museum Clayton New,york.
gtrip1
gtrip2
gtrip3
It's missing its cylinder head "Hats"
Model T with one hat off !
gthat
This is a very nice Gray twin T that is gasoline and kereosene capable as shown at Calvert Marine museum 1906
Gtcal
This man said he was a factory man (didn't say what factory} wanted to remove the rear carb mounting plate and examine the fuel nozzle ?
GTe
Gtnoz
Marc possible to get some good photos of your engine ?
Searcher
Username: searcher
Post Number: 551
Posted on Saturday, February 09, 2013 - 05:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This 3 cyl. Gray was exhibited at Mystic in 2007. The caption indicated it was a high performance racing engine. I don't know enough about Gray to speculate whether it was a redesigned/refitted T or a different design altogether. I just know it was one fine looking Gray.
Marc DeLeonardis
Posted on Saturday, February 09, 2013 - 05:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Rich,I'm pretty sure the pictures from Mystic are the same motor.
Robert
Username: robert
Post Number: 510
Posted on Saturday, February 09, 2013 - 06:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I assume those brass caps were spun? They look slightly different from each other.
What was the purpose of the nut and bolt/stud(?) in the middle of the "GRAY" embossed side covers? They are obviously well secured by four bolts already.
Post Number: 2983
Posted on Saturday, February 09, 2013 - 06:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thats a real Beauty !
These engines were a true two port / three port design, all of these engs I have seen carbureted the two port inlet, the Gasoline /Kerosene Twin above is the only T I have seen with twin carbs for each cylinder that are on the three port intake ?
1914 Illustration- Hope its readable
lr
