Electronic ignition
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Electronic ignition « Previous Next »
Martin
Username: martanke
Posted on Monday, March 05, 2012 - 08:19 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone know if there are conversion kits for electronic ignition available for Graymarine straight sixes with Delco distributor?
/Martin
Doug Kimball
Username: doug11k
Post Number: 80
Posted on Wednesday, March 07, 2012 - 10:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Martin,
Try this link to Pertronix Ignition
http://pertronix.carshopinc.com/product_info.php/products_id/88936/1442
Martin
Username: martanke
Posted on Thursday, March 08, 2012 - 09:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank you Doug,
the link points to a conversion kit for IHC Tractor 4 Cyl. What's the relation between Graymarine and IHC tractor?
miro forest
Post Number: 606
Posted on Sunday, March 11, 2012 - 08:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There should be a plate on your distributor with a model number.
The guys at Pertronix need that number to make sure you've got the right one.
They make 12 V, 6 V, positive ground and negative ground versions.
I found that contacting a good knowledgeable local auto parts distributor is the best approach.
They can reach right into the Pertronix database.
Here's the link to Pertronix
http://www.pertronix.com/prod/ig/ignitor/default.aspx
