Gray marine fireball RH crankshaft
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray marine fireball RH crankshaft « Previous Next »
GERALD LUTZKE
Username: jerry0361
Posted on Friday, February 01, 2019 - 10:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Help? I need a RH crankshaft for a fireball v8. Can be from either a 250 or 327 AMC. These were found in many Century boats
Jim Staib
Username: drrot
Post Number: 255
Posted on Saturday, February 02, 2019 - 08:34 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Do you have a part number for the one you need? I have one from a 4" bore engine. Was just a short block so CID is unknown. Will be in Milwaukee Monday but can't get it Magnafluxed in time. I'm in Mchenry, IL
