Transmission and housing same for gra...
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Transmission and housing same for gray 4 and 6 cyl engines? « Previous Next »
Mark Walick
Username: lesnlearned
Post Number: 10
Posted on Wednesday, November 27, 2019 - 04:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm hunting for a transmission housing that's compatible with a '40-'41 gray engine. I've been shown a potential match. The housing matches, but don't know enough about trannies to know if it's mounted to a 4cyl engine if it's compatible w a 6. I assume so, but would love to learn more about these transmissions. Thank you and pls don't be shy!!
Ned Lloyd
Username: ned_l
Post Number: 203
Posted on Friday, December 13, 2019 - 12:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have some sixes, but no fours to compare to. I would think they are different.
Mark Walick
Post Number: 11
Posted on Tuesday, December 17, 2019 - 09:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Ned. You have six cyl transmissions or engines with the transmissions for comparison? I've ruled out the four cyl option as they are indeed different. Here is the mounting plate I have for reference.
Ned Lloyd
Username: ned_l
Post Number: 206
Posted on Friday, January 10, 2020 - 03:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have one Gray '109' with a hydraulic Paragon reverse gear (1:1) - gear on the engine. I also have one Gray '109' with the mechanical gear (1:1) - gear and engine separate.
Mark Walick
Post Number: 13
Posted on Sunday, January 12, 2020 - 11:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Ned. This is a post war model, yes?
Ned Lloyd
Username: ned_l
Post Number: 216
Posted on Monday, April 20, 2020 - 09:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Oops, sorry I missed your reply and question. Yes, both mine are post war engines
