Graymarine Distributor Parts ID
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Graymarine Distributor Parts ID « Previous Next »
Rob
Username: rdurrant
Posted on Monday, August 31, 2020 - 12:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can anyone tell me what cap, rotor and points go on this distributor? I am unable to identify it on any lists or documents. If someone could point me in the right direction I would appreciate it.
Delco Remy 1110958 9A16
Jim Thomson
Username: brownboat
Post Number: 32
Posted on Monday, August 31, 2020 - 10:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Delco Remy 1110958 was used on a 59-60 V-8 135, 170. Contact set:1918148,D-103;condenser:D-200,1869704;Cap:D-305,1917247;Rotor:D-403,1917249; This info is from Delco Remy Marine Applications booklet 1960 Edition
Rob
Username: rdurrant
Posted on Tuesday, September 01, 2020 - 12:40 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Jim! I have been looking everywhere online. I guess I should see if I can find an old manual.
Rob
Username: rdurrant
Post Number: 8
Posted on Thursday, August 11, 2022 - 02:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
FYI - I was able to have this rebuilt but looking for a replacement o-ring. How do I ensure I get the right one that holds up to heat and engine oil. Does anyone know where to source?
