HOLLEY BROS CARB #18144
Old Marine Engine » Carburetors, Mixers, Vaporizors » HOLLEY BROS CARB #18144 « Previous Next »
STEVE K
Username: steve_k
Posted on Saturday, January 12, 2008 - 03:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I HAVE AN OLD HOLLEY BROS CARB #18144.I CAN'T FIND NO INFO ON. JUST WONDERING IF ANYONE KNOWS WHAT IT FITS THANKS STEVE
Searcher
Username: searcher
Post Number: 219
Posted on Sunday, January 13, 2008 - 01:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You have a c. 1906, Holly, Model L. The attached copy of a Holly ad illustrating this carburetor is of poor quality but it is the best I have. The Holly Model L is on the left, the Model WJ is in the right.
Searcher
Username: searcher
Post Number: 220
Posted on Sunday, January 13, 2008 - 02:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I should have noted that these carburetors had a number of applications. Your carburetor was clearly used in marine applications but also may have been installed on an early automotive engine. It may have been on a stationary engine for that matter bit I suspect it was intended for marine or automotive use. Like any competitive business, be it 1906 or 2008, you made your product adaptable to as many applications as possible.
