Anyone know where to find 3/4"reed va...
Old Marine Engine » Carburetors, Mixers, Vaporizors » Anyone know where to find 3/4"reed valve for Schebler D? « Previous Next »
Jonathan Lee
Username: nelson
Posted on Sunday, April 12, 2009 - 04:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hoping to replace a vaporiser with a Model D carb, which I have, but need to find 3/4" reed valve. Does someone know a source for these or a machine shop that could make one??
Post Number: 442
Posted on Sunday, April 12, 2009 - 06:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The check valve is usually a poppet valve. I bought some modern valves on Ebay, 2 for $9.99. Enter brass check valve, you should see them. They come with a plastic valve, but they unscrew and you could replace the valve with a brass one if necessary. They would probably work as is for a show engine, I would modify them if using in a boat.
