New to me acadia
Old Marine Engine » Acadia » New to me acadia « Previous Next »
Robert Reinhart
Username: reinhart
Posted on Thursday, January 07, 2021 - 07:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just acquired a barn find motor sn:45769. Two cylinder and in maybe runnable condition. It is missing one ignitor assembly, anything out there for a parts source?
I am new to the site, Thanks.
miro forest
Post Number: 1113
Posted on Saturday, January 09, 2021 - 09:48 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There are quite few Acadia engines in working conditions. You might have to be a bit patient , but you will be able to get help for sure.
Ignitor bits and pieces are not too hard to make up if you cannot find old parts.
I expect that ignitor parts from stationary version of those engine will likely fit OK
Robert Reinhart
Username: reinhart
Posted on Monday, January 11, 2021 - 03:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
upon further knowledge of what I am looking at, I see the timing mechanism is also missing. Hoping to find these pieces in the garage it was stored in. Are the ignitors unique to the engine manufacturer or were they outsourced?
Post Number: 2622
Posted on Monday, January 11, 2021 - 05:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Robert,
Do you need the front or the back ignitor? They are mirror image of each other.
Robert Reinhart
Username: reinhart
Posted on Friday, February 19, 2021 - 03:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I need parts for the flywheel end, thanks.
Dave Trickett
Username: dwandi
Post Number: 9
Posted on Thursday, March 11, 2021 - 07:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Robert, I have sent you an email, I am confident that I should have what you need for the engine.
L Boehl
Username: queeniebee
Posted on Thursday, May 13, 2021 - 08:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am new to this discussion board.
Question about mounting a 1930 Palmer YT-1 in a Chesapeake Bay Crab Skiff. Can anyone tell me what Palmer recommends for the maximum mounting angle of the engine? The mounting is currently 15 degrees. Is this too acute? The answer is most likely in Dick Day�s YT-1 Manual, I had a copy and cannot locate the manual.
Thank you for any information you can supply.
