Kermath oil seals
Old Marine Engine » Kermath » Kermath oil seals « Previous Next »
Jim Thomson
Username: brownboat
Posted on Sunday, February 24, 2013 - 06:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Kermath Sea Twin that I am assembling, I would like to replace the front and rear oil seals. There are no identification numbers on them, so does anyone know where I can get replacements or where I can get a cross reference to a Timken oil seal (or other brand)number? The parts book uses Kermath numbers and not manufacturer's numbers as far as I can tell.
Robert B. Price
Username: rbprice
Post Number: 421
Posted on Sunday, February 24, 2013 - 08:19 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Use the OD, shaft diameter and seal width to search in a Chicago Rawhide or Garlock catalog to find a part number. Then call your nearest Applied Industrial Technology or Kaman Industrial Technology, and give them the part number. Be patient with them when they ask you what kind of machine the seal is used in.
Cheers
Bob Price
Jim Thomson
Username: brownboat
Posted on Sunday, February 24, 2013 - 10:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for the reply, I will use the ID,OD and seal width as suggested and see where it goes. Jim
