Kermath 20
Old Marine Engine » Kermath » Kermath 20 « Previous Next »
Tim Sullivan
Username: onetim
Posted on Monday, December 16, 2019 - 12:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Picked up a Kermath 20hp, No. 10469 My start plan is to see if it can be freed up, and have started with just Kroil at this point, any tips?photo photo
Tim Sullivan
Username: onetim
Posted on Wednesday, December 18, 2019 - 10:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ok, how about some background on it, This is located on Pelee island ONT out in lake Erie, it was stored in a barn that blew down in 1973, and was stored in a 55 gallon drum from then till now. My guess is its around a 1925ish. The air supply going to the tappet? cover looks different.
Before trying to turn the engine i guess i should remove clean all drip oil lines, clean and fill the tail shaft grease cup, and direct oil all bearings, and kerosene soak the bores.
Tim Sullivan
Username: onetim
Posted on Friday, December 20, 2019 - 09:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Found a Kermath manual from approximately the same year as my engine at the Puget Sound Maritime museum. The director Alice Barnes has very kindly offered to send me a digital copy of the manual.
miro forest
Post Number: 1063
Posted on Friday, December 20, 2019 - 09:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Well, about 35 years in a drum - probably a combination of condensation and "set" have done a number on the pistons in those cylinders.
Most likely you'll eventually take the head off, but before you do that take your pick of penetrating stuff Kroil , PB Blaster, Auto transmission fluid plus acetone, and a lot of patient patient waiting.
After all it's taken over 3 decades to get it to this state.
You'll find that there will be one piston that just won't let go - and that's when you need to contain your enthusiasm .Some folks have worked engines like this for well over a year before they get results.
OR . . . maybe . . . you'll get lucky.
Once you get some movement, go back whence you came and do the "back and forth" sometimes only 10 or 20 thou. You'll eventually get there.
When you do get more movement, think about getting (forcing ?) very light grease or light oil into the bearings if you can, before turning the shafts (crank and cam) too much . The bearings are not usually the source of being "stuck".
You'll be hefting that engine up, down and around. Set yourself up in a "handy" workplace if you can including some kind of lifting arrangement.
Miro
Ned Lloyd
Username: ned_l
Post Number: 207
Posted on Friday, January 10, 2020 - 03:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
OK, ....... That's a pretty neat engine! I will look forward to your updates. Good luck!
Tim Sullivan
Username: onetim
Posted on Tuesday, February 18, 2020 - 11:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sorry it's been a while, Thanks for the tips on freeing the engine, the head does not come off on this vintage, so the only hope is through the plug holes or from under. I figure I have 20 good years left, so I hope that's enough time, hehe
miro forest
Post Number: 1071
Posted on Friday, February 28, 2020 - 06:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here's some info on stuck engines that might give you a tip, although I think you are probably well along the way
That headless feature is a pain, ain't it.
https://www.gasenginemagazine.com/gas-engines/repairing-seized-engines
