Which Oil to use?
Old Marine Engine » Stuart Turner » Which Oil to use? « Previous Next »
simon owens
Username: whichword
Posted on Wednesday, August 24, 2011 - 07:00 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I wonder if someone can help me? I have just bought a boat with a 10 hp Stuart Turner Petrol engine in it. It says to use a mix of 20/50 oil in the fuel. Could anyone recommend to me the best oil to use. Many thanks.
steven john page
Username: fairbanks
Post Number: 72
Posted on Wednesday, August 24, 2011 - 10:37 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi simon, all the manuals state an oil SAE 30, The same as the gearbox oil. regards steve
simon owens
Username: whichword
Posted on Wednesday, August 24, 2011 - 10:46 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Many thanks Steve. Will go and find some!
Malcolm Russell Ward
Username: russell
Post Number: 53
Posted on Wednesday, August 24, 2011 - 02:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Simon, welcome aboard. Straight SAE 30 is the best if you can get it. I get it from Fuchs in NZ but any vintage car bod would direct you. There was a discussion on this some years ago which you will be able to find. Two stroke oil will do but has some minor problem and I forget the details. The proportion is 1:48 oil/petrol.
Paul Vecovsky
Username: paulvec
Post Number: 20
Posted on Tuesday, August 30, 2011 - 07:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi simon! use valvoline standard two stroke oil in 50 to 1 mixture! works well, never had a problem! SAE 30 will foul your sparkplugs at idle or slow running. Don't use marine grade two stroke as it's semi synthetic and won't lubricate the main bearings correctly!
cheers paul
simon owens
Username: whichword
Posted on Tuesday, August 30, 2011 - 07:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Many thanks Folks. Will reply in full when engine fired up and running 'well'!
Thomas P Montagu
Username: tom_montagu
Posted on Thursday, December 29, 2011 - 02:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Reference various enquiries regarding the correct oil specification for the 2-stroke Stuart Turner marine engines. I have a P5MC which is my next engine to be restored and its owners manual states:- SAE30 oil at the ratio of 1/3rd of a pint in a 2 gallon can (20cc in 1 litre). I have a J2 Kelvin marine engine in my canal narrow boat and this engine also requires a SAE30 low detergant oil. 3 oils I can suggest are:- CASTROL CLASSIC XL (which I use), MORRIS OILS Golden Film SAE30 and SILKOLENE OILS Chatsworth 30 Classic (Silkolene is part of the FUCHS group). All these oils are low detergent oils and are also the reccomended oil for engines that have no oil filters (as per a large number of historic marine engines).
